innovative mount kit + ???? = GSR motor in EK
already did a search couldnt seem to find an answer
im looking to buy this motor mount kit
and i need to know what else is need to drop in a GSR motor into my '96 EK...keep in mind i dont have any mounts what so ever on the GSR motor.
which parts would i need to complete this, if i am correct w/ the motor mount kit i wouldnt need to bracket for the drive side mount correct?
also has anyone has any experience with innovative mounts? which to get street,race,track? i prefer it to be stiff but without the vibration.
Re: innovative mount kit + ???? = GSR motor in EK (dash_0n)
you need #6 from your civic, #7 from a 99-00 si
if the mounts are stiff enough you dont need #1,8,9 & 10. But you can use them and from what I know (not too confident with this info as I only have had EGs) the rubber parts (#8 & #9) are from the civic and the metal brackets from the teg or 99-00si (#1 & #10)
Re: innovative mount kit + ???? = GSR motor in EK (ek_will)
I've gotta bring this back from the dead.
I'm looking into getting these for my car, but I can't envision how they actually bolt up. Specifically on the driver side, where I've got the OEM ball-type mount (#4 in the diagram)...
Anyone have a picture of these things actually installed in a 96-00 Civic? I tried emailing Innovative, but all I got was a response saying that I needed to buy that particular part number.
for b series into ek u will need #7 from the picture above, #8, #19,#21,#22..if ur going to get aftermarket mounts like the innovative or hasport then u will not need #4, otherwise u need #4 if ur going for the stock factory look
I understand that.
I have #8 in the pic above connected to #4 in the other pic.
My question was how the Innovative mounts actually bolt up to the vehicle.
I've seen plenty of pics of the mount itself, but none of them installed in a 96-00 Civic.
Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">I understand that.
I've seen plenty of pics of the mount itself, but none of them installed in a 96-00 Civic.</TD></TR></TABLE>
ive been acouple with the hasport setup which his pretty much the same but i cant find the pics anymore...i have a pic of my hasport but the pic isnt so good..here is mine just picture the innovative one in its place
okay this is what you need a number 7 fom the picture from a b16 and a b16 driverside engine bracket. and number 6 from the old engine and take the stud off the old single cam driver side one to put vback on the new motor
Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">
EXACTLY what I needed... I just couldn't picture how that mount bolts in.
And to everyone else, I'm not some noob doing my first swap. The engine has been in there for 6 years, so I think I understand which mounts I needed to do the swap... But thanks..
i am also doing a gsr swap into my ek
i have
ek9 rear engine bracket
ek9 timing belt side bracket
innovative billet mounts 60A
can i just use the 3 main mounts
so i dont have to use the other oem mounts
since it will look cleaner
i have
boostincoupe
10-04-2006 01:59 PM
JDM CTR EK
07-23-2003 05:55 AM
