Innovative motor mounts, got some questions.
For you guys that swaped the dseries out for bseries, what hardware (bolts, washers...etc) did you use? I asked because I just found out that Innovative doesnt supply hardware with their mounts.
Second question, whose all using the 75a inserts? How is it daily driving with them?
Re: Innovative motor mounts, got some questions. (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz »</TD></TR><TR><TD CLASS="quote">ek or eg?</TD></TR></TABLE>
ek.
ek.
Re: Innovative motor mounts, got some questions. (latitude)
What hardware are you questioning about? I am a innovative mount dealer and usually all I have to use is the stock bolts and stuff. Which mounts did you get the billet or steel?
i would assume that you would just use the reg mount bolts, the chassis brackets dont change your just changing the mounts that plug intot he chassis, so you should just need 3 reg chassis mount bolts, and 4 or so nuts for the studs.
and right now im using a 75a conversion innovative mount and i dont notice a whole lot of difference rides pretty good
Re: (lsjon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboparts »</TD></TR><TR><TD CLASS="quote">What hardware are you questioning about? I am a innovative mount dealer and usually all I have to use is the stock bolts and stuff. Which mounts did you get the billet or steel?</TD></TR></TABLE>
the bolts, washers things like that. i had hasports before on my previous car and they came with all that. i haven't got anything yet because of this.
Re: (lsjon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsjon »</TD></TR><TR><TD CLASS="quote">yes you can use the stock mounting hardware</TD></TR></TABLE>
that's weird never heard of that before, oh well.
Re: (latitude)
Anyone actually used the dseries bolts on the bseries mounts? I don't want to be hunting for bolts and washers
Called Innovative, they said it will...
Yes the d-series bolts will work, again remember your not changing the chassis brackets your just changing out the mounts. just make sure u have the correct nuts for the b-series studs, and u will need 2-3 beries L bracket bolts.
Ive only used em for 2 months so not sure if they will compare to longevity of hasport, but their very well built, and the ride comfort is the same but also depends on what bushing ur ordering.
Re: (lsjon)
we all use the stock bolts.. stock honda bolts
the 75 is not too bad.. the 60a is way stiffer then stock and works well there are hi horsepower enthuienst that need the stiffer mounts for different purposes if your just daily driving get the 60a but if you want hard pushing heavy footed performance get the 75a. Camp1320.com will give free bushing upgrades till the end of jan on full kits
Modified by camp1320.com at 11:37 AM 1/9/2007
Re: (lsjon)
if you are running aluminum innovative mounts you CANT use you stock harware the mount bolts arent long enough. the bolt on the bottem of the tranny mount on the car will need to be longer.
Re: (SOHC_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_EK »</TD></TR><TR><TD CLASS="quote">
if you are running aluminum innovative mounts you CANT use you stock harware the mount bolts arent long enough. the bolt on the bottem of the tranny mount on the car will need to be longer.</TD></TR></TABLE>
i think the new billet kits include that longer bolt now....If you didnt get one and bought the mounts from us we will glady send you one
BlueRex1020
08-14-2009 04:19 AM
RyCeRoCkeTz
03-20-2007 04:46 PM
FritzInTN
01-20-2004 02:51 PM
