Injectors is not clicking !!
I have problem with my EG civic B16A. The injectors is not clicking . I checked the wires and it is connect correctly. Then I checked the main relay and its fine. I thought maybe there is some thing wrong with ECU because I checked with tester if there is any signal coming out from ECU for injectors I found there is not. I changed the ECU and its the same. Now I'm using Hondata s300 and its not showing any problem just vtec spool because I disconect the vtec. I check the distributor and its fine. All fuses is OK. What else I have to check or I can try ?.
Please Help.
Please Help.
Jordan Bishop
15
03-30-2018 09:07 AM
Matthewhughes
29
08-05-2014 03:18 PM
bootlegcivic
08-06-2005 10:07 PM
civtegra_hybrid
02-06-2005 04:33 PM
