Injectors?
Injectors?
Got the AEM fuel rail. Need to kno what injectors I should go with. Any help on this would be great. Also what would be a good fuel system? I will be running 18 - 19 PSI at the track.
Thanks,
Mike
Thanks,
Mike
Re: Injectors? (icantthinkofaname)
ok so i assume you are going turbo.
instead of saying what PSI you are running at the track, what are your HP goals. boost is relative to HP, but it can vary greatly from setup to setup
Re: Injectors? (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">once again
what is your HP goal
PSI means ****.</TD></TR></TABLE>10 psi on a tdo4 is ***** talk......10psi on a t04 is a real mans ride.
