Injector questions?
Injector questions?
I know this might be a stupid question but does anyone know if there is a difference between the 91 HF injectors and 91 si? Will your performance suffer from using stock 91 HF injectors on a si setup? I did a HF to Si change over recently but have not had time to find some si injectors and the car seems to be very low on power especially on the lower end. Compression on the block is good....any suggestions?
thanks
thanks
Re: Injector questions? (thao4life)
I have HEARD theat all D series injectors flow the same, but I do not know if that holds true to the older models.
SOHCrx
11-27-2003 07:39 AM
