indepently wiring a speed sensor
i cant get my speedsensor to work for the life of me , i check to see it its getting power at the plug(good) im sure its not my cluster and im sure the new sensor is good , does any one know of a way to wire it indepently to the computer its says its port b10 and i tryed linking the signal wire from the sensor directly to the ecu but still nothing ? is there a way to wire vtec with out the speed sensor ?
Re: indepently wiring a speed sensor (HATCHMO92)
Have you checked the pins in the harness side of the plug?
Have you checked the ground on your thermostat housing? |
