im missing two sensors completely with my swap how will it affect the performance?
hey guys im putting an LS engine into my 94 DX and a few things are bothering me, the place for the )2 sensor in the header is filled with Jb Weld and i just dont have the sensor that goes into the intake tube(not really sure what thats called), but i just wanted to know what you guys think i should do about this, buy the wires and sensors? thanks a lot
Re: im missing two sensors completely with my swap how will it affect the performance? (madhatter07)
if you are staying OBD1, don't worry about the sensor in the intake tube thats for obd2 ecu/cars.
as far as the o2 sensor goes, you need that. go to a muffler shop and ask them to weld up a bung before the cat.
Re: im missing two sensors completely with my swap how will it affect the performance? (BOBBYdigital
ok i work at a muffler shop so thats not too hard, do you think IAS would sell me the sensor along with the wires, could someone post a pic of where these wires come out of on the harness?
the O2 sensor has a square type of 4 wire connector which is different from the most common round 2 wire connectors along the harness.
should come out of the harness behind the block / under the intake manifold...
near the oil pressure sensor or the transmission 3 prong vehicle speed sensor.
i have an extra o2 sensor if you need it. i had it in my car and i have a 95 hatch with a 95 ls swap. let me know if you need it
bussey_03
07-07-2010 02:25 PM
