I'm getting tired of this!!!
Okay, there have been problems from the beginning. Anyways... today i was completely free of any problems. Atleast for about 9 hours I was. I finally replaced my axle today and so the clicking noise has gone. No more tranny leaks, no funny idle and the car was driving great. 1hr ago i pull up to a fast food place and my check engine light goes on. WTF??? Now What??? Anyways, If it goes back on in the morn, how do i check what code it is throwing? I mean, I don't have a manual and I just can't get my hands on the Helms manual like everyone says to do. Will a chilton or haynes be good enough??? Or if anyone can instruct me on how to check the code, I would be greatly obliged. Atleast then i could post what came up. Thanks
Peace
b16a sirII
Peace
b16a sirII
Re: I'm getting tired of this!!! (hb_racer)
There is a little 2 pin plug that is not connected to anything over your ecu....under your dash/glovebox. Put a paper clip in there as a jumper and the check engine light will flash the code. A short flash is 1...and a long flash is 10. A chiltons manual should have the codes in them
HTH
HTH
Re: I'm getting tired of this!!! (Blown90hatcH)
thanks... so a chilton would be good enough???? Oh, also, do i put the paper clip in both the holes??? or just one??? (haven't looked at it yet... just going off what you said.) Or connect the two pins???
Peace
Peace
its gonna be a little blue connector with two holes in it , just put both ends of the paper clip in the connector and you're ready to do the test
Re: I'm getting tired of this!!! (you2envious)
there are no jumpers and no led.... look... and please tell me what to do.
one side:
the other side:
Peace
[Modified by hb_racer, 4:34 AM 4/9/2002]
[Modified by hb_racer, 4:41 AM 4/9/2002]
one side:
the other side:
Peace
Re: I'm getting tired of this!!! (Brian*Black99Si)
there is nothing above it... do you mean on this???? in the circle??? Nothing is on that. either side!!! Help... hahaha For reals though, i just want to know now... the check engine is gone... and yes, i've reset the ecu... and no more check engine... there was a wire really loose, i just plugged it in and it was okay. I just want to know how to check for a code next time.
Peace
[Modified by hb_racer, 4:47 AM 4/9/2002]
Peace
behind the right side of the glove box, above the blue circle, under the dash. get on your back and look up there you will find it.
Re: I'm getting tired of this!!! (fire7882)
Just put a wire in the pinout C4. Run that to the positive side of a switch, ground the switch. When you turn your car into the accessory mode and flip the switch your check engine light should blink. If you dont know how to read the blinks let me know. This is what I did on my car and it worked.
Yager-
Yager-
Re: I'm getting tired of this!!! (ImportHatch)
The thing that the plug is in is bright *** green its pretty hard to miss and the actuall plug is brown it will be tucked up in your dash right where everyone else said once you get it out just do as they said with the paper clip oh and I dont know that the codes are in a Chiltons
Re: I'm getting tired of this!!! (Dx4dR93)
1-oxygen content 63-secondary oxygen sensor circuit
3-manifold absolute pressure (map) sensor 67-catalyst system
5-manifold absolute pressure (map) sensor 70-automatic transaxle
6-crank angle sensor 71-74-random misfire
7-throttle position sensor 80-exhaust gas recirculation
8-top dead center position 86-engine coolant temperature
9-number one cylinder position 90-evaporative emission system
12-exhaust gas recirculation system control system leak
13-atmosphere pressure 91-fuel tank pressure circuit
14-electronic air control 92-evaporative emission control
15-ignition output signal system insufficient
16-fuel injector
17-vehicle speed sensor
20-electronic load detector
22-vtec malfunction
23-knock sensor
41-oxygen sensor heater
43-fuel supply system
45-air/fuel mixture too rich or too lean
48-primary heated oxygen sensor
54-crankshaft speed fluctuation sensor
61-primary oxygen sensor circuit
63-intake air temperature
Here are some of the codes if you have not already found them
16-fuel injector
22-vtec malfunction
23-knock sensor
cool and thanks... i'll look for it... also the codes are in chiltons... but what can you expect from a 16 dollar manual.
Peace
Peace
im sorry but OT: my tranny is leaking too..where the hell is the leak coming from? im suspecting the inner joint on the passenger side axle. thank. you.
Re: I'm getting tired of this!!! (B18C5-EH2)
