Ignition Set-Up-wires, connectors to ignitions. 96 Civic
I am trying to get my car started and I am trying to figure out which connectors on the steering wheel hook up to the Start motor. I understand turning the key closes the circuit to B+ to the starter, but idk if I have all the NEEDED connectors wired. You know?
Here are the only connectors NOT connected to anything. And from what I can see and tested, they have to destination.
ALL the but the yellow have an unknown destination. The yellow one goes to the gauge cluster. So any help is very much appreciated.
Re: Ignition Set-Up-wires, connectors to ignitions. 96 Civic
On the B+ terminal on the starter there should be constant battery voltage. The S terminal wire is the one closed by the start relay. Make sure you have that. If no, check the starter relay for clicking.
Ok we got it started, missed a brown connecter to the fuse box but still wanna know what those 2 blue and 1 yellow connecters go since the green went to the cluster. cluster isnt working now BTW but no other plugs for it.
DDTECH
20
11-16-2012 07:23 AM
.adam.
02-18-2010 09:08 AM
mardoiii
10-28-2008 05:37 PM
BigRonDawg
04-19-2006 04:25 PM
