Ignition coil problem, Please Help
Old 04-24-2005, 11:31 AM
RomoGuy's Avatar
Default Ignition coil problem, Please Help
have a 92 dx HB, with b18c gsr. Ignition coil went out, changed, the Distributor rotor and cap, thinking thats the problem. Found out my coil was bad, changed it and within 20 seconds it burnt out again. This happened twice, Any Ideas? igniter maby? if so is there a way to test the igniter? Im running an NEC igniter, I do have a spare b16 hitachi if that would work.
Old 04-24-2005, 01:43 PM
RomoGuy's Avatar
Default Re: Ignition coil problem, Please Help (RomoGuy)
help please
Old 04-24-2005, 04:28 PM
slotec's Avatar
same thing happend to me make sure none of your wires are touching inside the distributor
Old 04-24-2005, 04:39 PM
civictildeath's Avatar
Default Re: Ignition coil problem, Please Help (slotec)
do you have the Hitachi or Tec style dizzy??
Hitachi is intechangeable with any other Hitachi form 92-00 i know for sure so borrow from friend if possible to check or
to test ignition module, remove wires from module ( black/yellow, blue(1), yellow/green, and blue(2) )
turn ignition on and check battery voltage between black/yellow wire and ground.
if no voltage present, check for open circuit between the wire and ignition switch.
if present proceed.
with ignition on, check battery voltage between the green ground. if none, check ignition coil and the green or white/black wire btween the ICM and the coil
Old 04-24-2005, 07:15 PM
RomoGuy's Avatar
I have a TEC style dizzy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">do you have the Hitachi or Tec style dizzy??
if present proceed.
with ignition on, check battery voltage between the green ground. if none, check ignition coil and the green or white/black wire btween the ICM and the coil</TD></TR></TABLE>
Old 04-24-2005, 07:22 PM
i do not believe but am not 100% on this that the Tec will not work in the Hitachi.
the Tec style should be interchangeable but again not sure.
know anyone with a Tec style that will let you borrow theirs for a couple minutes??
Old 04-24-2005, 07:26 PM
RomoGuy's Avatar
Default Re: Ignition coil problem, Please Help (civictildeath)
I got a friend with a b18c1 ob2, not sure what kind of dizzy he has, but I dont wanna burn his coil out, what am i suppose to find out by using his?
Old 04-24-2005, 07:44 PM
by using someone's that works, you will know if it is that part.
if you burn it out, then you have a short in the wiring or in the ECU.
if it doesnt work and doesnt burn out, then it is something else
Old 04-26-2005, 09:17 AM
RomoGuy's Avatar
Fixed it! problem was the ignitor, I took out the NEC igniter, and replaced it with the a b16 hitachi obd2 ignitor. Started up, adn I let it idle for 5 mins, didnt shutoff
Daccordex
09-12-2013 01:56 PM
Kyogie12
12-14-2011 04:30 PM
dsettlemoir
11-19-2009 07:40 PM
hotaccord243
10-28-2009 04:13 PM
ParistsCP
10-22-2008 07:24 PM
Quick Reply: Ignition coil problem, Please Help
