if axle nutts are too tight does it ruin wheel bearings?
Re: (nortel)
the torque spec is over 100 # ft i believe... and i also think that the axle only mates the hub so no matter how tight you go no force is on the bearing...
Re: if axle nutts are too tight does it ruin wheel bearings? (nortel)
Yes, it should shorten their life.
Common sense should dictate that anything overtorqued is bad...
Electrician
Re: (nortel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nortel »</TD></TR><TR><TD CLASS="quote">the only axle nutts on a civic or integra..the big 32mm</TD></TR></TABLE>
Well it's called a Spindle Nut and it's rated at 134 lb-ft. That's why I asked what "axle nuts".
It shouldn't cause any damage.
Re: (johann)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johann »</TD></TR><TR><TD CLASS="quote">honda has a service news saying it will cause bearing damage</TD></TR></TABLE>
Thats good because it WILL damage them.
Re: (johann)
that's just common sense here.
L2ILL
02-25-2013 07:27 AM
L2ILL
10-22-2012 01:38 PM
