idles drops down even lower then normal after engine reaches certain temp
well ive had this problem for a while. my car is a 96 civic ex, its now boosted and running a obd1 ecu and i still see it happening.. not that i thought boost was gona fix anything
when my runs for a while and the engine temp gets towards normal, the idle drops down to normal 900rpms or so.
then as it gets a little warmer, nothing dangerous, just after driving around town or sitting in trafic a few times, i notice, like a switch, it will switch to idling at 450-500rpms which seems very low.
whatever chenge is taking place, if it happens while idle, i can notice it happen like a switch, all the sudden idle drops.
my random guess would say some kind of temp sensor is messed up.
Re: idles drops down even lower then normal after engine reaches certain temp (d15nonvtec)
same here 00 gsr in a 94 dx coupe, the only code it throws is o2, noc sencor. idle drops only on chipped ecus not stock ecus.
Re: idles drops down even lower then normal after engine reaches certain temp (7808)
same problem. when i'am at a stop light or drive thru, my idle drops to 500, rpm but when ac is on its goes back to 1000 rpm why ....
Re: idles drops down even lower then normal after engine reaches certain temp (streetracerjoey210)
mine does it on chipped obd1 and stock obd2 ecus. i think i may have a defective fan motor, now that i think of it, it doesnt seem to come on anymore. i was thinking maybe this happens when the fan is supposed to turn on.. not sure. . but my car never overheats, it only 30 degrees tho
