idle question...
Boba Connoisseur
idle question...
92 si, b18c1 obd1...
Timing is correct; both ignition and cam.
No vacuum leaks.
Coolant level is fine.
No codes.
My car idles around 300-400 rpm once it's warmed up...
UNLESS
I drive for about 30+ minutes on the highway or after an autocross, then it idles at the normal 700-800rpm.
I cleaned the IACV out awhile back and that didn't seem to do anything.
My only thought is the O2 sensor is old and tired, could that be it?
...and no I don't want to play with the idle screw on the throttle body, I want to fix the problem.
No vacuum leaks.
No codes.
UNLESS
Re: (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 »</TD></TR><TR><TD CLASS="quote">almost every Honda Ive ever driven in idles like that unless the lights are on, its just the way they are i guess</TD></TR></TABLE>
around 300-400??
how is you thermostat and the housing i don't think its the o2 sensor and yeah its good idea not to touch the idle screw cause that's not your problem
around 300-400??
c 2
05-12-2007 11:36 AM
