Idle problums...
Idle problums...
Ok i just finished a b16 gsr swap....
B16 block gsr head.....
ok after the swap i get a surging idle... it is only sometimes but it is to 1000 to 1500..... some one said that it might bee air trapped in my cooling system.... now if it is where do i bleed it from... my old bleeder was on the b16 head... any though
Re: Idle problums... (goldjdm)
If you have air trapped in your system I believe you should take off your radiator cap and let your car run for a lil while and do a few cycles (when you radiator fan comes on then goes off you system has completed a cycle). Its pretty much letting the system burp itself. Refill the system as necessary. I could be wrong but search it up to verify my statements. And if burping the system doesnt do it you can take off your FITV valve and screw back in the lil white plunger looking thing and that should take care of the problem.
Skyhigh07
01-15-2009 11:48 AM
