IDLE problems any suggestions
OK so far ive done adjusted idle screw and throttle cable, plugs,wires,rotor,cap, cleaned out the IACV, got all the air bubbles out of the coolant, and even went to with a y8 intake manifold. Still the Idle is hitting at 500rpm when warm, any suggestions. Or could this mean i need a new IACV.
Re: IDLE problems any suggestions (Spartanic)
nope<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spartanic »</TD></TR><TR><TD CLASS="quote">How does the car drive? Does it die on you?</TD></TR></TABLE>
Re: IDLE problems any suggestions (sleepyhamsterlx)
while car is running unplug the iac if the car dies its good if not then you need to clean it out with carb or brake cleaner then put it back on and run the car the unplug it. i might be backwards on this it is kinda late.
check the codes
adjust the timing
let me know if that helps?
check the codes
adjust the timing
