Idle Problems
Old 06-09-2010, 06:36 PM
94civicz6's Avatar
Default Idle Problems
Alright this is the situation. The car's 94 civic with a D16z6. It's having a weird idle problem that only happens when the car is warm. When the car is warm and sitting still it idles erratically and surges from 800 to 1000 repeatedly. I replaced the map sensor and no change. But If you unplug the iacv it stops and idles steadily , but it also will stop is you unplug the tps with the iacv plugged in. But which makes more sense the iacv or the tps being bad?
Old 06-09-2010, 06:44 PM
95EG2's Avatar
Default Re: Idle Problems
IACV... If the problems goes away it u unplug it u found the problem... same problem with my z6
Old 06-09-2010, 06:46 PM
95EG2's Avatar
u can drive with it unplugged but when u go to take off everytime it will surge alittle bit... honda dealership about $220 to replace other then that u have to order it online
OriginalCronite
10-31-2013 11:31 AM
B17DA-SON
02-05-2010 09:23 PM
e30FTMFW
09-26-2008 10:42 AM
mikeunreal2
03-29-2006 09:27 PM
boostin1cam
07-20-2005 05:39 PM
Quick Reply: Idle Problems
