idle problem
idle problem
so my gf's 95 coupe is idling very weird... well it actually just revs on it's own when she stops at a light or something... don't know what it could be so anyone have ideas on what it would be and how, if i can, fix it? thanks in advance ht
Re: idle problem (VRD^don)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRD^don »</TD></TR><TR><TD CLASS="quote">check for vaccum leak. her IACV might need alittle cleaning as well. any CELs ?</TD></TR></TABLE>
Bingo, I would recommend the same thing.
Resident Gearhead
Re: idle problem (yesSiReK)
Check for leaky vacuum lines first.
Older Hondas are infamous for vacuum leaks around the throttle body. Spray TB cleaner around it and if it bogs down/stutters *bingo* vacuum leak. <old trick
If that doesn't work, try spraying around the intake manifold gasket and listen for the stutter.
PhilMac
01-14-2008 11:35 AM
