idle help...not iacv
I got some new b18c5 pistons in my b18c1 engine and now i have an idle of 1000 rpm and 1200 rpm it jumps back and forth between the two when the car is at a stop. any help would be nice. I know its not the iacv or the fast idle valve because i checked and this idle only happened after i installed the itr pistons in. any idea?
Re: idle help...not iacv (gsr96cx)
well you had to unplug the whole head harness to pull it off so i would double check all of yur connections and make sure you didnt plug in the wrong plug....also try to clean out your IACV as i may have gotten dirt in there as it was it unplugged when you did the pistons
Re: idle help...not iacv (vtecb18c)
get some brake cleaner, throttle body cleaner, or something similiar, and spray down the intake manifold.. check for vacuum leaks.. sounds like you have a leak
thanks alot guys i found the problem. i had to bleed my coolant. there was air in my coolant lines, and i just had to adjust my throttle body so i was getting less air and more fuel to fit in with the itr pistons since its a little higher in compression now. Thanks again for the help.
