idk the engine in my car....read plz and see if u can help
i have a 99 ex coupe and it has a b16 in it.... the ecu is a obd1 p28 and i dunno exactly wht the motor is...it has a wiring conversion but idk if its converting to obd2 or 0 where can i look up the vin numbers on the motor to find out wht yr it is
Re: idk the engine in my car....read plz and see if u can help (sdj11)
u can read what motor it has cuz each block is stamped with B18C1, B16A etc etc. if you running a OB1 P28 ECU u probally got a chipped ecu. if u wanna run the OEM ECU u need a P2T (i have one for sale). there should be a vin# plate on the block im unsure where. hope that answers your questions.
Re: idk the engine in my car....read plz and see if u can help (djviet2000)
ahh so it maybe a obd 2 motor..cuz he said it was a jdm 99 b16 but it doesnt say b16a2 so idk
There will be a green vin tag on the front of the tranny and 1 on the block above the oil pan behind the exhaust manifold/downpipe and only if it is a 96 and newer motor. I dont believe JDM motors had the tranny vin. You can also look at the markings on the head just above the exhaust manifold between cylinder 3/4, The first circle will have a 2 digit number which is the year made meaning if it says 9/1 it would be out of a 1992. Hope this helps
Modified by GSRcivicDX at 11:08 PM 4/14/2008
ehh the tranny is out of a gsr it has the green tag..the block i need to look at but it has a new head.this motor was kinda frankenstiened together and im fixing it... i just need it to last till i get my gsr motor built...and the markings on the head said 90 the one i have now is off a 99 si
Ikon
01-06-2006 03:16 PM
