Identifying the hoses
Old 05-24-2019, 11:11 AM
Default Identifying the hoses
which hose is this? And it is blocked so does it effect anything. Secondly what is the purpose of that U shape hose beside this blue marked hose? As my heater core is not hooked up
​​​​​​as you can see my heater core is not hooked up so where it goes?
Hasan Khurshid is offline
Old 05-24-2019, 01:28 PM
chrysler kid's Avatar
Default Re: Identifying the hoses
It's your heater bypass hose
chrysler kid is offline
Old 05-24-2019, 02:47 PM
I think you are saying U shaped is heater bypass but what about the blue marked hose? Can you tell me why heater is bypassed?
Old 05-24-2019, 05:55 PM
Sure. The heater core isnt connected because the previous owner is dumb.
The u shaped hose is on the back of the thermostat housing and circulates the hot water coming out of the cylinder head before the thermostat opens.
Old 05-24-2019, 05:56 PM
Old 05-24-2019, 06:04 PM
Thanks but i am the first owner and the engine swapped from D16y8 to D15z6 so from then it is disconnected and I am from Pakistan so here mechanics are dumb and they disconnected it as they think it will not be used because of weather conditions.
Now I am confused may be the heater core is leaky or damaged and it is very difficult to inspect and remove heater core.
What is this hose for marked red?
Old 05-24-2019, 06:14 PM
tony_2018's Avatar
Doesn't look like the heater core is connected to the engine, so you're not getting any heat.
tony_2018 is offline
Old 05-24-2019, 06:31 PM
What about this red hose?
Old 05-24-2019, 06:32 PM
Secondly any test to check that heater core is in what condition? As it is very difficult to physically remove it and inspect it.
Old 05-24-2019, 08:29 PM
The barb is broken off of your heater control valve box... and likely why you have the heater core bypassed. The only proper way to test the heater core for leaks is to connect it to the engine and fill the cooling system and warm up the engine to create the proper amount of pressure. If it leaks, you have to pull the dash. If not... you have heat. Find another heater control valve and reconnect.
The hose in your last pic is to the PCV valve which is installed into the oil separator box.
JRCivic1 is offline
Old 05-24-2019, 10:31 PM
Thanks for your help. Is there any problem if running the car without heater?
Old 05-24-2019, 11:32 PM
Freedo_Civegra's Avatar
No problem unless you live in a cold area or an area that receives cold weather. It would be better for you to get some block off caps or a hose that properly fits the fittings on the engine without kinking.
Freedo_Civegra is offline
Old 05-24-2019, 11:35 PM
Thanks for the help. BTW I live in Karachi Pakistan and here it is very hot
  • Ask a Question
Question Title:
Description:
