IAT Sensor
My civic was throwing cel 10. IAT. I replaced the sensor with another one from a b16a1. My car is tuned with Crome Pro (boostedb16) and there's a red wire running from the sensor to the ecu. There's another black wire running off also. I figured it was a ground so I tryed to ground it to a spot on the valve cover and a bracket that holds washer fluid I think. It never worked. Do I need to ground it to the body/frame ? Should that wire go somewhere else? How can I get rid of this code?
Re: IAT Sensor (smokingemcee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokingemcee »</TD></TR><TR><TD CLASS="quote">My civic was throwing cel 10. IAT. I replaced the sensor with another one from a b16a1. My car is tuned with Crome Pro (boostedb16) and there's a red wire running from the sensor to the ecu. There's another black wire running off also. I figured it was a ground so I tryed to ground it to a spot on the valve cover and a bracket that holds washer fluid I think. It never worked. Do I need to ground it to the body/frame ? Should that wire go somewhere else? How can I get rid of this code?</TD></TR></TABLE>
The colors on a factory obd1 harness should be red/yellow wire & a green wire.... You probably fried your iat sensor again https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: IAT Sensor (mtber)
Buy a mutlimeter and make sure the wire doesn't have any current running through it before you go grounding anything..
aaaaaa shiza! So replace again and ground somewhere else?
What about those tools that light up when electricity is present is that what your talking about?
why not just let the poor IAT go to the ECU like its meant to do?
Re: (axtran)
I don't want to mess with the ecu if i can just ground it anywhere. So i need to dissconnect the battery when i do this?
