iacv y7 mani -> y8 mani
the car is a 98 dx coupe...in the process of my turbo install, i swapped my y7 manifold with a y8. i also swapped ecus to a obd1 ecu (p75)...so i ran it with the y7 tb for a while (knowing that it was wrong) and i finally got around to putting the y8 back on it. so i have the mechanical part finished, but now im stuck with the wiring of the ecu. i went off of this:
but when i got to the ecu part i couldnt figure it out...is there a diagram for my year civic? because the top says 99-01 civic...i printed that diagram out and nothign seemed to match up...anyways here are some pictures of my setup...maybe someone can tell me what wires im messing with:
to the ecu
from my car to the obd2-obd1 conversion harness
everything
thanks in advance
to the ecu
everything
thanks in advance
Re: iacv y7 mani -> y8 mani (96-EJ6 B18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C »</TD></TR><TR><TD CLASS="quote">I'm not sure exactly what your asking...you will have to swap the IAC plug to work with the Y8 IAC.</TD></TR></TABLE>
yeah...i already did that...but according to the iacv fix on that picture i am supposed to do some ecu wiring...and that is where i am stuck. in between the iacv fix picture and my pictures there is a little paragraph..not sure if you missed that or not
Re: (alacard)
I think you're confused. The "wiring" that they explain is just telling you which wires from the 3 wire plug, to match up with the 2 wire plug. You don't have to run any extra lines to the ECU. All in all, they are saying match the yellow/black wire from the 3 wire plug, to the green/black wire on the 2 wire plug. Then the black/blue wire to the black wire.
Re: (paopao)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paopao »</TD></TR><TR><TD CLASS="quote">I think you're confused. The "wiring" that they explain is just telling you which wires from the 3 wire plug, to match up with the 2 wire plug. You don't have to run any extra lines to the ECU. All in all, they are saying match the yellow/black wire from the 3 wire plug, to the green/black wire on the 2 wire plug. Then the black/blue wire to the black wire.</TD></TR></TABLE>
no no...ive done this already....there is still some ecu wiring though...the diagram shows it under "step 1 [iacv pinout fix]" ...but the problem is that the diagram is for a 99-01 civic, and i have a 98
Ekevans08
12-12-2012 06:11 AM
-JSpecEk*9-
04-21-2006 01:09 PM
seeeya04
04-11-2006 06:16 PM
