iacv problems
iacv problems
i am having trouble with the idle on my car...i throw a code for a iacv and my car will stick itself at 1500-1600 rpms and then it won't come down until i restart the car or even sometimes even have to diconnect the battery terminals.....the car will try to find and idle between 500 and 1300 rpms when the code isn't on.....its a 2000 civic si.....please give feedback if there are any ideas on the subject....thanks
john
john
Re: iacv problems (Ricey McRicerton)
what should come out of the iacv, and also what is a price that i could see if needed to replace this item? thanks for your help.....
Re: iacv problems (allmotorsi04)
being that the actual problem wasn't with my IACV I don't know if that is what is wrong with yours. I just know a vacuum leak will sometimes throw the IACV code. When the vac line was off, it would idle normally for a minute the jump up to about 13-15K and then drop, the jump right back up, and drop and on and on. I had actually adjusted the throttle until it would idle correctly with the leak before I noticed it.
the.hamburglar
05-10-2007 08:46 PM
