iacv problem
Old 01-14-2013, 07:01 PM
Hmong EM1's Avatar
Default iacv problem
I been having iacv problem on my 99 civic si with jdm 00 gsr swap. It would idle at 1.5k and become jerky. So far I have clean and change the iacv with 4 different one, each one would work good for a day or two start doing it again. Now i dont what to do next.
here video of it idling
Old 01-14-2013, 07:31 PM
Former User's Avatar
Default Re: iacv problem
CEL codes?
Does the engine have a FITV? If so, clean and adjust it.
Have you bled the cooling system?
Old 01-14-2013, 09:53 PM
Hmong EM1's Avatar
CEL is P0505. There no fitv on it. I already bleed the cooling system till fan kick on 2 time.
Old 01-18-2013, 01:46 AM
Hmong EM1's Avatar
update: ok so i clean the tb and spray brake cleaner around intake manifold to try find leak but there none. i also swap out the ecu with another one to see if ecu is bad but same thing.
Old 01-18-2013, 04:15 AM
Markb16a's Avatar
I am having the same thing and I have been working on my car for the last 2 months to figure it out and I cant get it at all. the same problem your basically having.
Old 01-18-2013, 09:05 AM
Test the TPS and ECT sensors.
Old 01-18-2013, 03:54 PM
hytech_shed's Avatar
Have you checked your PVC valve, hose and grommet ?
silverlude80
08-02-2011 07:43 PM
Ed992
11
08-06-2009 09:11 PM
krysted9354
11
03-04-2009 04:27 PM
Powelly
02-21-2009 12:17 PM
dsadas89das78934
13
03-14-2004 11:30 AM
Quick Reply: iacv problem
