iacv
Old 08-16-2013, 01:02 PM
jordyjay's Avatar
Default iacv
Hi guys. I just did a b18b swap on my 96 civic dx hatch and changed the iacv wires from a three pin to two pin and it idled at 2500-3000 so o changed the iac valve ...still doing it and i still have cel for the iac so im not sure where to go from here
Old 08-16-2013, 01:08 PM
jordyjay's Avatar
Default Re: iacv
Just to be clear i changed the pins on the ecu as directed but its not working
Old 08-16-2013, 01:09 PM
ElectronBlue00's Avatar
Default Re: iacv
My first assumption would be to check the wires for continuity...
I would also check for vacuum leaks as I just experienced myself today will result in the same issue.
Old 08-16-2013, 01:23 PM
Technical Hero
HondaPartsHero's Avatar
Default Re: iacv
What ecu?
Old 08-16-2013, 06:25 PM
jordyjay's Avatar
Default Re: iacv
97 integra ecu
Old 08-16-2013, 07:17 PM
Technical Hero
Default Re: iacv
Take detailed pics of your wiring and post it
Old 08-16-2013, 07:22 PM
10psiLsEf2's Avatar
Default Re: iacv
What happens if you remove your throttle cable off the throttle body? It could be a tight throttle cable cause the throttle plate to stay partially opwn
Old 08-17-2013, 06:17 PM
jordyjay's Avatar
Default Re: iacv
I kind of thought there was something wrong with the throttle body but why would it throw an iacv code?
Old 08-19-2013, 08:20 PM
jordyjay's Avatar
Default Re: iacv
Old 08-20-2013, 01:34 AM
Technical Hero
Default Re: iacv
Old 08-28-2013, 06:08 PM
10psiLsEf2's Avatar
Default Re: iacv
Try adjusting you idle screw on your throttle body.
Its a flat head screw on the front of the throttle body.
Id say 12 oclock on the body
Kman1371
02-14-2017 08:22 AM
BIGef
05-04-2012 12:16 AM
supracrx
01-07-2007 08:06 PM
Mr. JDM-GSR
08-29-2005 11:33 AM
ic108
01-28-2002 10:24 PM
Quick Reply: iacv
