IAC (Idle Air Controller) Hum / Noise?
Old 02-20-2004, 07:10 AM
BryanPendleton's Avatar
Default IAC (Idle Air Controller) Hum / Noise?
I had this strange humming noise after swapping in a B16A2 into my 96 Coupe. I finally found the source of the noise. It was the IAC, or Idle Air Controller. I figure hey, I will replace it and call it a day. So I picked up a salvaged unit and even plugged it into my car while it was running to confirm operation and no noise. All checked out. I get home remove the IAC and replace it with the one I just bought. I fire the car up and the noise/hum continues. I am dumb-founded.
First, does anyone know why the IAC solenoid would hum? Second, how can I fix my problem. I would just assume drop the $130 for a new OE IAC, but I am afraid to hook it up out of fear that it will "break" too.
Old 02-20-2004, 07:11 AM
Spade's Avatar
Default Re: IAC (Idle Air Controller) Hum / Noise? (BryanPendleton)
3 wire or 2 wire?
Old 02-20-2004, 07:37 AM
Default Re: IAC (Spade)
Per Chilton, the M/T is 2-wire and A/T is 3-wire. I will need to double check, but is should be 2-wire, as I used a 97 M/T EX Civic harness for the swap, BUT my car was an automatic to start with and I converted it. I have confirmed voltage (~12.8v) via voltmeter.
Old 02-20-2004, 07:40 AM
Spade's Avatar
Default Re: IAC (BryanPendleton)
....does the hum go away when the IACV isn't mounted to the IM?
Old 02-20-2004, 01:35 PM
i'll check that one out.
Shermanef9
07-26-2008 11:29 PM
ScubaStevo80
03-18-2008 05:48 AM
EsQueue
06-19-2005 08:06 AM
Gump
12-06-2003 02:48 PM
Quick Reply: IAC (Idle Air Controller) Hum / Noise?
