I STILL NEED AXLE HELP WITH MY H22A4 COUPE
Whats cookin...i have a dropped 1993 civic coupe with a H22A4 engine....and my axles broke, so i put a 88 integra outter and 93 itnegra inner....and it still knocks when i go left or over a bump..I also replaced the wheel bearing already.. But, when my car sits for a long period of time, and i drive its not that bad, but the longer i drive it, the worse it gets....WHAT THE **** IS THE PROBLAMO! CV Joints, Suspension, Half shaft, Intermediate shaft??!?!?!
Re: I STILL NEED AXLE HELP WITH MY H22A4 COUPE (h22ame)
Check to make sure your passenger side axle hasn't popped out on you. When I put the 90-93 teg axles in my car, they never stayed in. I enlarged the snap ring and everything. When you are going straight, they are fine. But when I would hit bumps or make hard left turns, I would get a knocking sound and vibration from the passenger side. Turn out the axle would keep popping out of the tranny.
You need to get a prelude inner joint for the axles to stay seated in the tranny.
