I searched.. B18 swap into a 98 EK?
Okay, I know there are probably hundreds of threads on this. But, I just want a list of things I need to swap the engine and trans from a 1997 GSR into my 98 EK. I have both complete cars so I think just a few mounts but not sure. And, is there any DIY threads on this swap? Mostly want to know what I need to do as far as wiring on the ECU.
Re: I searched.. B18 swap into a 98 EK?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-everything-you-need-know-about-b18c1-gs-r-swap-into-eg-eh-856396/
https://honda-tech.com/forums/hybrid-engine-swaps-18/1-8-dohc-vtec-550976/ <<<this is a b16 though. start there. They're a gen older but it should be similar.
You can find threads, it just takes time but it looks like nb may have beaten you to it. It can and will be a royal bit*h but just hang in there and it is very rewarding. Good luck,.
yeah search function blows...alot of people will go to google and do it within site honda-tech.com and seatch what they want.
I'm doing this right now, I will tell you what you need.
For the motor:
Rear T-bracket off a 99-00 SI
Engine post mount off a 99-00 SI with drivers side mount
Torque mounts off any B-series
For power steering:
You need a Civic SI power steering pump, it will bolt to your stock lines
For AC:
You need a Del Sol or CRV AC bracket, this will allow you to reuse your D-series compressor
Shift linkage off any 94-01 Integra or 99-00 SI.
For ECU I would run a P28 with a OBD2->OBD1 jumper harness.
If you have any other questions let me know.
For the motor:
For power steering:
For AC:
For the motor:
For power steering:
For AC:
For the motor:
For power steering:
For AC:
For the motor:
For power steering:
For AC:
doesnt hasport and innovatives sell complete mounts kit for b series in a ek?? instead of pieceing it 2gether....
For the motor:
For power steering:
For AC:
jdm98civic
09-28-2007 05:45 AM
