i need help pretty bad
trying to finish up my first motorswap.
b16 sirII into a 94 del sol S.
How do i wire the vtec? what pinout in the ecu do i run it to?
im not very mechanically inclined, i have a few friends helping me out and they are kind of stumped too, they think its already wired for vtec.
any help is appreciated.
Re: i need help pretty bad (JdelMsolG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdelMsolG »</TD></TR><TR><TD CLASS="quote">
any help is appreciated.</TD></TR></TABLE>
If I remember correctly the del sol "S" ran off of a D15 non-VTEC, I think it was the Si that ran the D16Z6. Though I could be wrong, don't really know a lot about del sols. So if it's the "S" and I am right than it's not VTEC - which means obviously that it's not wired up.
My answer is the same answer I always give. Why? I think that it's the answer to all Honda ECU mapping problems.
Chipped OBD-I P28 with a B16 basemap program FTW.
If needed run a conversion harness from OBD-IIB to OBD-I.
It'll hook right up.
Though you'll still need to wire in the VTEC as the wires for VTEC on a non-VTEC engine simply...aren't there...
FAILWGN
Re: i need help pretty bad (aznej2)
A B16 from an SIR2 is already OBD1. No need to change. You are going to have to physically run new wires to 3 pins in your ECU. Let me try and find it for you real quick.
https://honda-tech.com/zerothread/1171263
Look at the third post down.
allmotorEG-SI
22
12-31-2008 09:17 AM
89civicb16a1
05-20-2006 09:50 PM
