I need help with distributor
Is there any tips for taking off and/or putting on a new distributor to a 98 civic ex? I do not know if there is a correct or an incorrect way to put on the new distributor so any insite would help greatly. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: I need help with distributor (irishgod247)
It should be only able to go on one way. Make sure that the o-ring is there and in good/new condition. Maybe put a little oil on it to ease install. You will see the two little tabs on the dizzy and the two notches on the cam. One is bigger than the other so it should go on one way.
Make sure that the dizzy sits flush with your head before installing bolts. DO NOT FORCE IT WITH THE BOLTS. If it isn't flush it isn't on right. Let me know if you get it figured out. |
I am getting the distributor in my hands on monday afternoon hopefully if it doesnt come by then I will have to find another source to obtain a distributor. Thanks for the info on the install.
