I need help deciding what engine to drop in my 93 coupe
I just recently bought a 93 coupe shell and im definetly going with force induction. I was thinking of going ls turbo. But my friends are trying to talk me in to do a SOHC turbo. Any info would be appreciated
Re: I need help deciding what engine to drop in my 93 coupe (4rceFedDeceiver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4rceFedDeceiver »</TD></TR><TR><TD CLASS="quote">If you have no answer for me keep you mouth shut smart one.</TD></TR></TABLE>
I did give you an answer, and thank you.
do a search man first or look in the FAQ's, to let you know you'll get the same answer from everyone else
Re: I need help deciding what engine to drop in my 93 coupe (Ninja_Jc7)
yeah im going to, thanks . I just mainly wanted to know if someone that has a sohc turbo has had good results with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4rceFedDeceiver »</TD></TR><TR><TD CLASS="quote">yeah im going to, thanks . I just mainly wanted to know if someone that has a sohc turbo has had good results with it.</TD></TR></TABLE>
SOHC Turbo is bad ***..
LS turbo is also bad ***...
What specific information are you looking for?
I told you to search because this has been talked about many many times before.
And by you researching on your own, you can use your mind and decide from there.
Re: I need help deciding what engine to drop in my 93 coupe (poison)
Im getting rid of my 90 eclipse GS turbo and moving to a honda. This is a the first time I post something thats why I wanted to know what people that has either ls turbo or sohc turbo their opinions and other peoples too.
Ok, that is understandable.
Have you tried researching the forced induction forum?
There are a lot of people who run SOHC boost on stock internals running almost 12's.
You could use your SOHC and salvage DSM turbo, 450cc injectors, intercooler, etc and run an FMU with a resistor box and put some nice ownage up on people.
really depends on funds. there is obviously more potential in b18b but it also cost more money.
the specific info that im looking for is if anyone has had any problems with it, or if anyone recommends any engine work before slapping the turbo on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4rceFedDeceiver »</TD></TR><TR><TD CLASS="quote">the specific info that im looking for is if anyone has had any problems with it, or if anyone recommends any engine work before slapping the turbo on.</TD></TR></TABLE>
Of course we can recommend throwing down internals to the motor for more boost. But on stock internals, depending on the motor and compression ratio, will depend on how much PSI you throw down on it.
Mainly on good fuel management, I have seen both on LS motors and SOHC running no more than 10 PSI on stock internals.
Plan on at least building the sleeves, different rods and pistons before throwing down more PSI.
DjN3M3S1S
Audio / Security / Video
07-23-2004 07:10 AM
