i need help with adjusting Camber
well, i have 00 civic and i don't have any problem with wear out tires or anything, but lately i was lookin my car from the rear and i noticed that my rear tires were sitting (// \\) like this. someone told me that thatz negative or something like that ,(don't know much about camber stuff)
i'm using GC with koni, and i've dropped about 2" front 1.75 on back
i know my toes are pretty good, cuz i've had my tires for awhile and my tires wear out evenly, not edge..
anyway, here is my question, without taking to shop for camber setting, can i adjust it?.. someone help me how!! thanks in advance!
Re: i need help with adjusting Camber (JDM-FREAK)
Use washers. You would place them between the upper arm and the frame to 'space' it out, thus eliminating some negative camber. If you have to use a lot of washers, you will need longer bolts.
Re: i need help with adjusting Camber (JDM Ninja)
Yeah, just like JDM Ninja said, it's very easy. I had roughly -2 degree camber and just used 2 washers. It's still got a little negative camber, but that's good. It helps when cornering, yet doesn't wear the tires very much.
DJNauTicz
10-09-2007 03:27 PM
todds94teg
09-05-2003 06:14 AM
