I NEED A CLUTCH AND FLYWHEEL ORDERED TONIGHT!! HELP!!!
at the jetties fishin'
ok, it's bad...not totally bad but bad....to the point I had to bypass the starter kill on the clutch pedal to crank the car.
considering that there's 88,354 miles on the original honda clutch and a turbo setup at 9psi for the past 15k I'm very happy it lasted THIS long lol!!
anyway, I'm going home over july 4th weekend where dad has a car lift but I have to have a clutch set and (hopefully) lightened flywheel in hand before hand.
best I've found on the net is at http://www.jegs.com where a ram clutch set is $233 and a ram flywheel is $349
help me make an order tonight guys I gotta get something but I really don't WANT to pay $600 for a clutch/flywheel set but I will if I have to...are there better deals to be had? I don't care if I buy from separate places but I need quality parts that will get here on time...
oh and no I don't need a damn 6-puck unsprung clutch setup haha
Re: I NEED A CLUTCH AND FLYWHEEL ORDERED TONIGHT!! HELP!!! (stackz)
You have a D series?
I have a clutch with about 5,000 miles on it and flywheel with pressure plate.
Re: (ironcheftony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony »</TD></TR><TR><TD CLASS="quote">go to one of the local racing shops, they should have atleast 1 of those instock</TD></TR></TABLE>
already been and they are even MORE expensive...damn I hate retail sigh...I only know of jegs and summitracing as far as mail order...are there any others that sell clutch sets and flywheels..
not looking for stock parts...I want a lightened flywheel and better clutch set than oem
Re: (Trial User)
if you're really desperate, https://honda-tech.com/zerothread?id=544082 ... let it go for...hMmm.. $25 for both!
where u located? let me know...
Re: (jdmsiR20)
Try http://www.clutchcityonline.com I've heard good things about them.
Try Poison. Good luck. Keep us posted..
check out groupbuycenter.com they have alot of vendors there, im sure someone has that for sale, however, check the vendors feedback before u order, some have some bad ratings, haha
Re: (stripes777)
"ok, it's bad...not totally bad but bad....to the point I had to bypass the starter kill on the clutch pedal to crank the car."
Am i the only one who doesnt get this statement? Im confused as to what exactly is wrong with you clutch. Since the clutch/starter switch that is connected to your pedal assembly has NOTHING to do with your actual clutch and everything to do with your pedal assembly and starter components.
If you cant crank the car due to the starter switch itself, the problem should lie in the pedal assembly itself or the switch.. now if your starter is bad it could be a number of other things.
Muydos
04-06-2012 05:30 PM
ludesrv
05-28-2006 07:13 PM
