I idle around 500 and below help
So after my del sol warms up lately it will idle at like 500\450rpm. It hasnt done this b4 and im wondering if its ok or not. Its a 1997 del sol si sohc v-tec with only 50k miles so.. im like whats going on here.. thanks
Mr. Indecisive
Re: I idle around 500 and below help (midwestdan)
if it idles irradically then you may have a vaccume leak or maybe its just the iacv but if its idling constantly at like 450-500 you can just adjust the idle.
Theres a little screw on the intake mani used to adjust the idle
you can use a screwdriver. flat head. you might want to change your pcv valve. had the same problem when i first did my swap, came out to be a bad pvc valve.
like $3 to fix.
like $3 to fix.
Re: I idle around 500 and below help (DeadEnd9009)
I'd say its just your idle screw, i polished my intake and messed with that screw and didnt know, but car would'nt idle. lol. the screw fixed it?
Modified by swap_killer7079 at 12:52 AM 6/22/2006
Re: I idle around 500 and below help (swap_killer7079)
I have the same problem but mines idle around 200 very low n it isint a steady idle it moves could it be a valcum leak?
Ohmega
19
03-09-2016 04:48 AM
pdiddy
12-10-2002 10:47 PM
