I have a 2000 boosted Si
Ok i am loooking into building my bottom end i just bought a b18c1 bare block. But I havent made my mind up on who i want to send the block to get sleeved? I hear great things about Golden Eagle, but then i heard darton does a good job sleeving to but they are a little cheaper then golden eagle and that you are just paying the extra $ just got the name golden eagle. so is there a huge difference?
so after I get it back i was going to do JE pistons and eagle rods.
im looking to hit 400-500 whp. so im just trying to see what would be the safest way to make it and what i should all do to the block?
its not my DD it just sets in the garage most of the time. I have a good turbo already t3/t4 57trim percision. I made 310whp on my stock b16 on 12psi. so just needing some more information on what would be the best for me to do before i start the build.
Re: I have a 2000 boosted Si
https://honda-tech.com/forums/forced-induction-16/benson-sleeve-darton-sleeve-2440386/
See if that helps! Honestly I know the basics and what should be done but never actually built a boosted vehicle so I'm sure there could be alot of better people to input on this. I know that a buddy of mine(wow a buddy story sorry) Does alot with boost and has good luck on benson sleeves.
Good luck with your build
so anyone else have any ideas???
what would be a legit setup?
sleeves?
piston?
rods?
fuel system?
springs?
retainers?
looking to hit 400-500 whp safely
sleeves?
piston?
rods?
fuel system?
springs?
retainers?
dart sell's an aftermarket block for b series i know jeg's has themDart Honda B-Series Engine Blocks
Product images may differ from actual product appearance.
Now Honda owners can discover the Dart advantage! Dart has applied their decades of racing experience to design and manufacture the first heavy-duty block for Hondas. Working in conjunction with leading industy professionals, they have engineered the Dart aluminum Honda block to solve the shortcomings of production blocks used in high-performance and competition applications. The Dart block is offered in two versions that replace the B18 and B20 castings. Both are built to withstand the extreme cylinder pressures created by turbochargers and nitrous oxide injection. Dart has increased wall thickness in all critical areas and beefed up the bottom end with steel main bearing caps. Best of all, Dart blocks are compatible with prduction Honda cylinder heads, internal components and accessories. The Dart Honda blocks are produced with an all-new tooling and are machined on state-of-the-art CNC equipment. They have added features that sport-compact racers and performance enthusiasts need to build powerful and reliable engines. Take a close look and you'll see why Honda dominate with Dart!
Features:
Dart B18 Block: Has stock deck height and choice of standard 81.5mm bore or optional 84.5mm bore.
Dart B20 Block: Has extra-tall 8.900'' (226mm) deck height and 84.5mm bore for increased displacement.
C355-T6 Virgin Aluminum Alloy: Aerospace quality C355-T6 Virgin Aluminum Alloy provides maximum strength and durability.
Ductile Iron Sleeves: Replaceable ductile iron dry sleeves are fully supported to reduce bore distortion and enhance ring seal.
Closed Deck Design: The closed deck design increases rigidity and improves head gasket sealing.
Steel Main Caps: The steel main caps and high-strength bolts increase bottom end strength and minimize bearing bore distortion.
Strengthened Main Webbing: Increases rigidity and improves head gasket and sleeve life.
Extra Large Water Jackets: Enchance coolant circulation around cylinder barrels.
Machined For Piston Oil Sprayers: Reduces piston temperatures and prevents detonation (Sprayers not included).
Precision CNC Machining: Ensures consistent high quality and eliminates expensive ''blueprinting''.
Features:
Man U FTW
Go to the Forced Induction forum and search. You'll find a lot more info regarding your question.
With the 57 trim you currently possess, you don't need to sleeve the bottom end unless you have the money and would rather have the security. As for the rest of the build, your piston choice is more a matter of preference than anything else. The compression depends on your power goals, sleeve situation and fuel grade.
If you have a budget in mind, checking prices would be a good place to start. You can't plan to make more power than your budget allows obviously...
I'm looking to spend around 4-5 grand I looked and called places
1000 to sleeve my block from ge, I want to sleeve because for safety.
800 for pistons
eagle rods
but I'm not really thinking about doing the head tho
I have a single walbro fule pump and aem fuel regulator. Should I change that as well??
But when I bore it out the shop I was going to said I should go with 84mm bore to get more mid range power. 2.0L but doesn't leave much more room for sleeve scaring??
800 for pistons
eagle rods
Man U FTW
I would start at 83mm. That is still a sizable increase over stock, but leaves plenty of 'meat' in case something does happen. For your goals, a single Walbro will be fine. That pump flows enough to make upwards of 500whp. The regulator you have is also fine...hell, the stock one would work.
Now to the head...you can leave it as is. There is no need to do anything but a set of a ITR cams would be a nice addition. At the power levels you're talking, you stand to gain ~40whp over a set of GSR cams.
thanks man you helped a lot! so im glad dont have to change up the fuel system. seriously itr cams will do that much power??? dang thought it helped but not that much. what do a set of them run?
Yes the itr cams will provide alot more power boosted over na. You can probably get a set of ctr or itr cams for around $250. If you are looking to do about 350whp there really isn't a need to sleeve it. But I can't say I blame you because you can always decide to go for more power that way. I am running stock b16 block bored to 81.5mm with ross pistons and eagle rods. Stock head with ctr cams. I am making 391whp on 19psi with a 60mm garrett. Before with the stock b16 cams I was making 369whp on same boost.
Yeah I heard ctr r more nasty then itr. But I'm looking to hit 400-500 so I wanna sleeve just in case I wanna do more down the rd. But should I also gEt a diff manifold? And I have a stock timing belt should I get a itr one little **** like that would help my timing better?
not a great boost guy. but if your running the stock one id say either machine that one or buy a new one. and depending on when you did your last one just for safety id say do it. idk if there's any difference but get a blue gates belt. will it make it better? no. just it wont break and destroy your hard work. unless you mean faster...which is also no. better timing youd need cam gears.
SpeedDreamz.com
03-26-2006 07:11 AM
