I have 2 questions.
Okay, I first wanted to know if anyone has a tutorial on how to remove a honda srs steering wheel. I know the basics I just want to make sure I do it right.
This question is for all you ground-control owners. How do you determine the ride height? Like say I wanted to set the coilovers to lower my car 2" would I just measure up the threads 2"? Or is it by trial and error? |
Re: I have 2 questions. (Happyman)
first you'll need to unplug the battery first
then unscrew the airbag holding points, then use 19mm to take the steering off. as far as coilovers, indeed its trail and error to some degree. as each car is slightly different and each side might not be up to the exact same measure. so experiment. |
Re: I have 2 questions. (eg6ajk)
Have no idea how to remove the steering wheel.
As far as groundcontrol coilovers go, im pretty sure its lowered/raised .25" per notch. Feel Free To Correct Me. https://honda-tech.com/forums/images...es/emsmile.gif |
