I got Si's Sway bar, what to do now?
Hi Everyone I have 96 HB, and lately I have been asking alot of question about putting an Si's sway bar on my car. We'll my Si's Sway bar finally arrived today, it only have two rubber bushing with it. It has not bolts or nothing.
So I am trying to start a shopping list of the parts I need to get in order to put it on my HB. Any Helps is greatly Apprecitated.
P.S. If you one of the people on the board that have done this, please post some pic if you have any and give me any info on it. And again thankx to all those that replies and this Board Kick ***..
[Modified by Greasemonkey, 5:08 AM 10/27/2002]
Re: I got Si's Sway bar, what to do now? (Greasemonkey)
i just did this swap with a few friends wednesday, you are gonna need a lot more, in order to make the si front sway bar work, you will need the SI lca's, endlinks, d-brackets, and shock forks. It's a lot of work and a lot of parts but it is WELL worth it. Im me if you have any further questions.
pictures? no, it looks just like any other stock sway bar on your car, just way beefier. It is not hard at all to do, everything is self explanatory once you get up there, it is just tedious and you need more than one person most of the time.
You only need to replace the front LCA's if you're adding a front sway. For the rears, there's already holes for the endlinks.
Re: I got Si's Sway bar, what to do now? (HENRY)
Re: I got Si's Sway bar, what to do now? (Eddie HatchBlack)
if upgrading to si front swaybar, you will need to get the lca's as well as shock forks and endlinks and anything else i listed up there.
For the rear, all 96-00 came with the same rear lca's so no need to upgrade.
