i got a rattling noise toward the front end of my civic is that the heat sheild and how could i fix
can someone help
Re: i got a rattling noise toward the front end of my civic is that the heat sheild and how could i
If it's your heatshield, just remove it. Is the rattling noise coming from underneath the front end and is it loud? Or is it soft?
like when i first start the car it rattle pretty load and when i hit the gas and yes its like coming from under the front drivers side
Re: (hypnotic)
its probaly your heat shield just rip that bish off
Re: (hypnotic)
This happened with my GSR. The heatshield rattled at 1500 RPMs. Get's very annoying. Just unbolt it and see if there's any rattling left.
Re: (BlueIntegraBoy)
yeah happened to me. the bolts are probably rusted and broke in half, if so you'll need to cut that piece with some dykes. wear glasses if you do... i had 8000 pieces of rust hit me in the eye. https://honda-tech.com/forums/images...es/emdgust.gif
i have the same problem, and i noticed it does it worse when it gets cold. I suspected the heat shield also.
Now which heatshield are we talking about? exhaust mani, b-pipe or cat? |
Re: (MrIllegalX)
it's most likely the one on the cat, but it could be any one on the exhaust system. you really just have to get under there and look.
Re: (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">it's most likely the one on the cat, but it could be any one on the exhaust system. you really just have to get under there and look.</TD></TR></TABLE>
well I guess I'll pull them all off. How do those O2 sensors come off? looks like a nut needs to be loosed then they'll slide out? |
Re: (MrIllegalX)
Mine was definitely the cat heat shield. Use an open end wrench and just keep turning the O2 sensor until it comes off.
