i cant get my fuel pump or my starter to work when the key is turned.
but when i hot wire them or jump em they both work fine.
Re: i cant get my fuel pump or my starter to work when the key is turned. (JDM_SOHC)
thats what it was in the first place and i noticed that the big black wire was cut so i re soldered them and got the guage lights to come on but only the oil and check engine lights came on. and it wont flash a code it just stays solid. ???
1 Post
Re: i cant get my fuel pump or my starter to work when the key is turned. (killacam661)
haha dude rewire that ****... i went an got a new switch from junk yard 15 bucks an just redid my own **** worked perfectly... as far as i kno those connections have to be 100% or its no can do..
Re: i cant get my fuel pump or my starter to work when the key is turned. (BUDtoker)
i just put a 94 dx motor into my 92 dx hatch. and some wire colors dont match up to the engine and ecu harness. i am thinking thats why i cant get the fuel pump to turn on when the key is turned on. and also the starter wont do anything when i turn the key all the way over. but i tested both the starter and the fuel pump by jumping positve power to them and they both worked. why will it not work when i turn the key on and over in the start position???
ok when you jump your starter and it works dont mean it aint broke the solinoid could be bad! and as for your fuel pump wire that **** to a fuse for the igniton some how! i cant tell you how to do it but im sure you can figure it out!
ive got the gauge lights to come on now. it was my battery . i know the wire color off the ecu is blue/white but i have four other wires left over after wringing it all up.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killacam661 »</TD></TR><TR><TD CLASS="quote">ive got the gauge lights to come on now. it was my battery . i know the wire color off the ecu is blue/white but i have four other wires left over after wringing it all up. </TD></TR></TABLE>
any chance for a picture?? 92's are wired for vtec an **** and 94s arent.. "i have a 94" so I kno the wiring harness's are a bit different.. so in essence im sure your gonna have a couple extra wires left over..
Ok so whst wires are supposed to be left over? There are two on the engine harness and 4 on the chasis one. Which wires do i have to wire together? Also i have the blue/white starter wire on the chasis but not at the clip end in thecengine bay. Its like a9 or something in the ecu clip , but i dont see it on the other side in the engine bay
what are fater green/ white wire on the big clip near the battery.that and a yellow/ red one is left. What are they for in your 94??
And on your engine harness what is the larger all blue wire on the larger clip by the battery.
Re: i cant get my fuel pump or my starter to work when the key is turned. (RyanG)
have you checked the main relay ynder the driver side kick panel. and the different colors on the wiring harness dont mean anything. every plug only fits in one slot, so itcant be mixed up
Re: i cant get my fuel pump or my starter to work when the key is turned. (fmrprojects)
does anyone have a picture of where it is? I looked for it and I couldn't find it, maybe its gone. Pics would help me find that sneaky bastard.
1 Post
yeh dude its dark out... once i get up "i get up early like 6" ill take some pics of my harness's plugs an wires an we'll see if we can match'm... because the only wire changing I ever did was just wired my harness for Vtec.. So everything else should be identical...
99ssinoc
08-26-2009 08:32 PM
therealeg6
07-03-2009 10:02 PM
