i can hear compression???????
i have a d16y8 and im cranking it over with a 17mm wrench on the crank pulley bolt, and i can hear a psssst leaking out.
my comp says 180 180 180 150 so how do i fix this?
Re: i can hear compression??????? (thebleek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek »</TD></TR><TR><TD CLASS="quote">i have a d16y8 and im cranking it over with a 17mm wrench on the crank pulley bolt, and i can hear a psssst leaking out.
my comp says 180 180 180 150 so how do i fix this?</TD></TR></TABLE>
Figure out where the pssssst is coming from. You can spray soapy water around the head gasket area the exhaust area and the intake area and see where the bubbles are coming from
so what does this leak mean? cracked head? warped head? unclean mating sufaces? leaky intake manifold?
and how do i make soapy water? like what consistancy? can i use windex or some **** ?
total dumb question, but needed to be asked
you need to do a wet and dry compression test do a dry on the cylinder in question them do a wet test by adding a small amount of oil to the cylinder if the comp is up signifigantly them bottom end if no signifigant change then its a head/valve issue
Re: (jimmy o.)
i did that already with the old head i had on there. i had to wipe out the oil in the cylinders when i did that.
so its def a head/valve issue
Re: (thebleek)
Do a leak down test, If its coming from the intake valve you will hear air escaping from the t/b, if its the exhaust valve you will hear it coming out of the exhaust(dunno about full exhaust), and if its rings you can pop your dip stick out and listen.
Seagull Management
Re: (thebleek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek »</TD></TR><TR><TD CLASS="quote">and how do i make soapy water? like what consistancy? can i use windex or some ****</TD></TR></TABLE>
Spray Nine is wonderful stuff if you want to check something for leaks.
Re: (94EG8)
if ti is a valve problem no amount of soapy water or other chemical is going to show bubbles. the only way to do it is pressurizes the cylinder in questions with it at tdc of its compression stroke and listen for air escaping from the exhaust or through the tb ( tb means intake valve problem exhaust means exhaust valve problem)
Location: ....................................................................................................
if you can hear it escaping then most likely a bent vavle but try pouring a tiny bit of oil down the cylinder with bad comp and see if it goes back up
Re: (thebleek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek »</TD></TR><TR><TD CLASS="quote">you consider a head internal?
im sure most problems can be diagnosed without a professional lol</TD></TR></TABLE>
I consider anything that can be covered in oil under use as internal
