i am officially stumped! someone help me!
car is a 96 ek hatch with 98 gsr,i have done everything to try and fix this problem before the starter was bad, ok replaced it then the alternator, replaced it then the battery, so i just replaced that and now it wont even turn over im frustrated beyond my limits. i put the key in the ignition and it like doesnt register that its in there, i cant turn on the radio and that sound when the door is open doesnt come on....battery is fine but the headlights wont work, hazards do...so does the horn... i am stumped and thinking about selling it to the highest bidder.... anything would help
thanks for your time.
Re: i am officially stumped! someone help me! (DCRbullet)
seriously, it was a little difficult to understand what the hell you were trying to explain here...
so did you even check if you had spark? gas? check your grounds?
when you put the key in the ignition, does it even beep at all saying the key is in? bad fuse somewhere?
Re: (coupej1)
if when you put ur key in the ignition and turn it and nohing happens as if theres no battery in it at all your not getting power since you replaced your battery check your main power distrabution fuse under the hood in ur fuse box its the on the bottom away from the windshield its a 80amp fuse kinda hard to blow but i had the same problem and thats what it was cost me like 2.36 or somthn at autozone to buy another one...
MattTwinTurbo
12-25-2003 11:33 AM
JDMvtecDRAGSTA
18
12-02-2002 10:51 PM
