HX upgrades?
HX upgrades?
I search and couldn't find one thread about D16Y5 upgrades, which I found kinda odd. I'm picking one up as a daily driver for a deal and want to see what upgrades I can make to make it a little peppier for daily driving.
It already has a Z6 tranny, I have heard throwing a Y8 manifold on can help with better breathing as well, I also plan on installing a DX or EX exhaust with the cat in the traditional location and a header instead of the funky HX manifold.
Any other suggestions? I am not looking to do a Y8 head swap just yet, so anything short of that.
Re: HX upgrades?
If you're gonna be buying a cat for the EX exhaust conversion i'd get a magnaflow direct fit high-flow catalytic converter for an EX.
http://store.summitracing.com/partde...5&autoview=sku
that's my only suggestion at the moment
be professional
Re: HX upgrades?
And if this were Zeroforum where the search function actually worked, I'd tell you that you didn't search hard enough because Bense posted a plethora of information on VTEC-E engine modifications several years back.
Re: HX upgrades?
As stated, don't wanna break open the motor, just looking to improve performance a little, I have a DA with a LS/Vtec on the bottle I built this last summer for going fast, this is just a commuter. If i wanted fast, I would boost it, and I wouldn't waste my time with the D series, I'd K swap it.
Back on topic though, I'll try to find that thread by Bense that was mentioned.
Again, the idea behind this car is a Commuter, not performance, I was just figuring I could make it a little less anemic with stock parts without breaking the bank. Thanks to the replies that helped.
Re: HX upgrades?
Here's Bense's thread: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/d16y5-d16b5-civic-cx-project-part-2-a-1414454/
Originally Posted by Bense
D16y5: 115hp, same head as y8, 9.3ish compression, y8 style intake manifold 90mm stroke, 137mm rod, 75mm bore. SAME HEAD AS Y8!!! CHECK THE PART NUMBERS!
Re: HX upgrades?
Finally found the thread if anyone is interested, God the new Search SUCKS!!!!!!
https://honda-tech.com/forums/showthread.php?t=1414454
*EDIT*
Ha, thanks, beat me to it.
*EDIT*
