HX TPS
HX TPS
So at 380,076 miles the factory TPS just randomly went out in a parking lot. No big deal since this was the original Honda TB the screws are not removable. So I took of the throttle body and after a little time with a grinder removed and installed a new TPS from autozone. Now I have adjusted the voltage to 0.483 volts with the throttle plate closed and engine off. However when I open the throttle plate to WOT I only get a max of 4.300. I know at WTO I should have 4.500. The car does idle now and drives so clearly the TPS is working but I am worried that it may not read WOT since it's 0.20 volts under what it should.
car is a 1997 Civic HX D16Y5 5 speed that is mostly stock with 380,076 miles.
Current voltage closed is 0.483 target 0.483
Current voltage fully open is 4.300 target 4.500
Re: HX TPS
You could move the idle side to .495-.500 volts and this will give you another tenth of a volt on the WOT side... however, the ECU is looking for only 4.200v to dictate WOT anyway, so it is actually not necessary to get to 4.500 volts.
Re: HX TPS
Thanks.
i checked it again today when cold and it is reading 0.480 closed but only 4.226 when opened by hand. I was reading a article where they adjusted the closed stop screw to set the wide open position to 4.5v and then adjusted the TPS to the new closed position.
VTPSD
37
07-10-2014 05:51 AM
import-tooner
07-03-2013 07:49 AM
