hx rims... do they clear gsr brakes???
will they clear gsr brakes if i do a conversion?
car is a 95 vx, getting hx rims and gsr brakes if they will clear. let me know. thanks in advance |
Re: hx rims... do they clear gsr brakes??? (93b18civic)
get a spacer and it will https://honda-tech.com/forums/images/smilies/emthup.gif
I think so because GSR brakes arent that much bigger then normal EX front brakes and HX can clear ex front brakes. Im 95% sure on this.
Youll probably have to do the spacing trick but you could look around on how to do that. |
Re: hx rims... do they clear gsr brakes??? (thenick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick »</TD></TR><TR><TD CLASS="quote">get a spacer and it will https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
Re: hx rims... do they clear gsr brakes??? (ophdehEEzY)
or you can grind down part of the caliper.
There is a thread on how to do it in the FAQ thread at the top of the page. |
where would i get spacers and how big (3mm?)
the only ones i could find at pepboys were more then 3mm....i haven't had a problem with them yet except i would rub at times....so i ripped out the fender wells https://honda-tech.com/forums/images...s/emsmilep.gif
ive been too lazy to grind the calipers down but with spaces and maybe open ended OE lug's you should be ok https://honda-tech.com/forums/images...es/emsmile.gif |
HX wheels will not clear EX brakes. The caliper must be ground down a little for them to clear.
Re: hx rims... do they clear gsr brakes??? (Dengar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dengar »</TD></TR><TR><TD CLASS="quote">or you can grind down part of the caliper.
There is a thread on how to do it in the FAQ thread at the top of the page.</TD></TR></TABLE> here it is not my thread but im bored so i went lookin for it https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/zerothread?id=555391 |
Re: hx rims... do they clear gsr brakes??? (screech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screech »</TD></TR><TR><TD CLASS="quote">
here it is not my thread but im bored so i went lookin for it https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/zerothread?id=555391</TD></TR></TABLE> who ever said boredom never produced results... thanks i appreciate it. https://honda-tech.com/forums/images/smilies/emwink.gif |
