overheating
overheating
96 civic was overheating while idle, checked fuses, 20amp cooling fan was blown, replaced it and still the fan does not come on except when I turn the engine off and then only runs for 30 seconds before turning off, any ideas?
I have also swapped the cooling fan relay with one I know works and same result.
Re: overheating
^ jump the fan switch. Its a blue and a black wire close to your passenger side headlight. If you feel that it is good, swap out the fan switch. It is located on your thermostat housing.
killahatch
05-04-2009 08:17 PM
ngoldsmith1@gmail.com
10
11-27-2008 01:04 PM
