How to tell if my SiR is fitted with an LSD?
Hello,
Would like to know but unsure where to look for the tell tail signs of having an lsd & abs?
Car has air con, gathers system etc.
Any help would be great
Thanks
Thanks
Re: How to tell if my SiR is fitted with an LSD? (Powelly)
LSD test- Find low traffic road, stop, rev to +/- 5K RPM, dump the clutch. 1 tire mark = open diff, 2 tire marks = LSD
ABS test- Use same said low traffic road, get the car moving to about 25MPH, put the brake pedal to the floor. You'll feel the ABS system through the pedal, and the tires should go intop a lock/unlock/lock/unlock sequence while the brake pedal is on the floor.
Enjoy!
Enjoy!
Re: How to tell if my SiR is fitted with an LSD? (Speed Kills)
I think some of the Honda's that came with an lsd had the trans case marked with it . As far as finding out if you have abs pop the hood find the bake master cylinder/brake booster. Look around that area for a rectangular block with a whole bunch of metal lines coming out
Re: How to tell if my SiR is fitted with an LSD? (instructor74)
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Kills »</TD></TR><TR><TD CLASS="quote">LSD test- Find low traffic road, stop, rev to +/- 5K RPM, dump the clutch. 1 tire mark = open diff, 2 tire marks = LSD</TD></TR></TABLE>
Umm, no. That won't tell you anything.
I have an open differential and can easily leave 2 tire marks when launching at autocrosses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. »</TD></TR><TR><TD CLASS="quote">http://www.ff-squad.com/technet/how-to/lsdcheck/
katman</TD></TR></TABLE>
These are the ways to tell.
As for the ABS, look under the hood for a piece like this: http://cgi.ebay.com/ebaymotors...wItem
. . . or like this: http://cgi.ebay.com/ebaymotors...wItem
That is the ABS pump. It will have several brake lines attached to it (they are cut in the photos).
Re: How to tell if my SiR is fitted with an LSD? (Targa250R)
This works if its stamped or if you pull out the axels, forgive me if it states that(i didn't read it all)
be professional
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Yeah that ****'s all good 'n dandy if the tranny's out of the car already...any checks for it while it's in the car besides the code?</TD></TR></TABLE>
No. You either pull the axles and look through the diff, or you look for the stamp on the case.
Enjoy!</TD></TR></TABLE>
That is completly wrong.
Re: How to tell if my SiR is fitted with an LSD? (-Gary-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GottaLoveHondas »</TD></TR><TR><TD CLASS="quote">
This works if its stamped or if you pull out the axels, forgive me if it states that(i didn't read it all)</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
No. You either pull the axles and look through the diff, or you look for the stamp on the case.</TD></TR></TABLE>
There it is, 2 times, thats a sure fire way to tell, And the tranny can still be in the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">I think some of the Honda's that came with an lsd had the trans case marked with it . As far as finding out if you have abs pop the hood find the bake master cylinder/brake booster. Look around that area for a rectangular block with a whole bunch of metal lines coming out </TD></TR></TABLE>
And that too for finding the abs stuff, may not be in the same spot as the booster, it will be very visible in the engine bay
i would look deeper then just wind it up and dump it cause my dx hatch with a y7 laid full posi marks ( pretty decent ones too ) i dought honda put an lsd in their non-VTEC econo motor...
yeah, my vx lays 2 lines when theres equal traction at both wheels.
one tire on grass, one tire on road, and drop the clutch, then see what happens. thats the easiest way to tell, or spin tires in a turn.
monEmakindave
04-07-2010 05:36 PM
ejprimo
05-16-2002 05:01 PM
