How to tell the difference between ECUs?
Old 10-15-2008, 03:40 PM
FRKWOO's Avatar
Default How to tell the difference between ECUs?
how can you tell if the ecu's from a automatic or manual transmission?
Old 10-15-2008, 03:48 PM
JDM_SOHC's Avatar
Default Re: How to tell the difference between ECUs? (FRKWOO)
All Honda ECUs have a part number which is located on the side of the ECU and inside the ECU on the connector. ex 37820-P28-A01
On the ECU the last 3 characters are broken down into 3 parts. "A" generally is used for US ECUs. "G" is European, and "J" is Japanese. There are other versions of this, but you get the idea. The second digit "0" typically means manual transmission, where a "5" means automatic transmission, and the last digit "1" is the version number.
*Info supplied from Hondata*
Old 10-15-2008, 03:56 PM
Spool This's Avatar
Default Re: How to tell the difference between ECUs? (JDM_SOHC)
whats a "N" usually stand for? ex; P08-N51
Old 10-15-2008, 04:02 PM
EJ8_Enthusiast's Avatar
North America?
Old 10-15-2008, 04:03 PM
Spool This's Avatar
Default Re: (EJ8_Enthusiast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8_Enthusiast &raquo;</TD></TR><TR><TD CLASS="quote">North America? </TD></TR></TABLE>
didn't have P08's in "north america"
Old 10-15-2008, 04:08 PM
JDM_SOHC's Avatar
Default Re: (Spool This)
N could be a revision of the ECU....
Old 10-15-2008, 04:09 PM
JDM_SOHC's Avatar
Default Re: (JDM_SOHC)
And also just cuz its N, doesn't mean the word starts with N... United States = A, Europe = G, Japan = J... See, sometimes it matters sometimes it doesn't...
h222accord92
08-13-2007 08:37 AM
ralphie14
15
01-31-2005 04:27 PM
flatty
05-03-2004 06:07 PM
Gmedalion
02-06-2002 08:39 PM
Quick Reply: How to tell the difference between ECUs?
