How to tell the difference between AT & 5spd engine harnesses?
I have an obd1 ex/si harness and I'm not 100% sure if its for an auto or 5spd transmission car. Is there anyway I can tell the difference?
I tried looking to see if it has a plug for the transmission lockup solenoid and that takes the same plug as the reverse switch on the 5 speed trans so there's no way to tell the plugs apart.Any thing else I should look for? I'm 90% sure it's from a 5speed car but I don't want to sell it or use it until I'm sure. The vss plug is also the same.
Is there even any wiring differences?
Seagull Management
Re: How to tell the difference between AT & 5spd engine harnesses?
There is no difference. All '92 - '95 EX/Si engine harnesses are the same. Lockup solenoid plug is used for the backup lights on a manual, same wire colors, same pinout, same harness.
thanks. I looked at a few dealerships online and they both carry the same part number so that's the conclusion I came to as well.
b18cEK
08-23-2010 07:06 AM
sacej2
03-07-2008 02:59 AM
dynamo
10
07-11-2005 04:11 PM
KID KUSOE
12-01-2003 06:16 PM
