how to take out old eg radiator support and put on new one
i kinda have an ideal of doing it but i dont know where all the spot welds are located and how many i have to drill out for the whole support to come off.......any hints......
Re: how to take out old eg radiator support and put on new one (hellshock2182)
hey kool man, plz keep me posted on that.......i would love to see what i would have to go through.....
Re: how to take out old eg radiator support and put on new one (b20vtech)
Ive seen a diagram of a DC2 showing where every spot weld is that holds the subframe on. Im sure one for an EG would be very helpful to a lot of people, myself included...any volunteers?
how many spot welds is there to drill for the eg6 radiator support to come out?
and write ups on this??
alot lol but ya i did it a few weeks ago ill see if i can take some pics,
p.s when u drill out the welds if you dont have a welder just use bolts to put the new one in. theres alot more drillin but its hella cheap
Re: how to take out old eg radiator support and put on new one (nekoabandoned)
what size bolt u use to bolt the new radiator support in?? and where did u drill to put the bolts in???
Glad someone's doing this. I have a bent support in my car and the hood won't latch the whole way. It's like $90 on ebay for a new support. I was wondering how to do it. I can't wait to see the picks so I can do this to mine. When you put the bolts in...is it as safe as welding it? I have to get my car inspected so I don't want to do it and it won't pass inspection.
Re: (b20vtech)
First of all, why are you doing this? Second how come you can't see the spot welds? is it rust? You can wire brush with a wire wheel atached to the drill around the mount and they should be visible then. I had to relocate both mounts for my k swap and it was very easy thing to do. I have no pics though
Re: how to take out old eg radiator support and put on new one (92_VX_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_VX_EG »</TD></TR><TR><TD CLASS="quote">Glad someone's doing this. I have a bent support in my car and the hood won't latch the whole way. </TD></TR></TABLE>
bump! for the same problem.
:edit: previous owner slammed the hood leaving the outward facing dents on my hood
Re: (b20vtech)
I just counted eighteen spot welds on each frame rail two right behind the headlights and two right near the corner lights for each side. I just started with a 3/16 drill bit and stepped up in 32nd's till I had all the weld drilled out.
My rad support came right off no problems.
dingusjt
05-09-2004 09:32 PM
