HOW to take off seats rails on my 94 Civic SI ?
Okay I just recently got 97 Civic CX seats for my 94 SI coupe I got two days ago.
So I heard that this is putting the EK seats into my EG is really simple and all I had to do is swap the rails from my EG seats onto my new EK seats..
To remove the rails, what bolts do I have to remove from my EG seats and can I bolt the rails onto my EK seats easily?
thanks everybody..
thanks everybody..
Re: HOW to take off seats rails on my 94 Civic SI ? (EL-Driver)
thanks everybody..
thanks everybody..
Re: HOW to take off seats rails on my 94 Civic SI ? (Evil_Wizard)
OKay that didnt really answer the question..
I know what tools to use, anybody know exactly how to remove the rails?
Rails are not compatible. To swap rails:
Take out the seat. Put seat on the side (hand lever up). Use prybar/screwdriver to pop off the seat-angle adjustment hand lever. Use a screwdriver to pull of the plastic side covor. Using pliers, remove the metal "circular tacs" (i'm not sure the technical term) that holds the seat covor onto the foam at the bottom of the seat back. Pull up the covor. Pull back the foam on the lever side. Undo the two bolts on each rail side that attack to the seat. Undo the two bolts that attack to the back (lever side) Undo the bolt that hinges the back to the seat (non lever side).
Reverse the steps to install. It also helps somewhat if you undo the metal wire that links the forward/back seat adjustment lever.
[Modified by project_mercy, 5:47 PM 2/17/2003]
